15 years ago --- Quote Start --- It doesn't work with Cyclone II, you have to sync on 25.0 MHz. Any reasons to assume, that your display won't accept it? --- Quote End --- Hi previously I was running PLL in normal mode, but after suggestion to use PLL in sync mode, I have compile it in this mode. But again display showing the same problem.(display accept the output but at the output whole picture break up into 4 segments.) I have selected the resolution of the display at 640x480. Thank You
