10 years agoBJT Code needs Debugging
Hi, I'm trying to compile the attached source codes. The NPN & PNP BJTs are in VHDL and the diode code is in verilog. I am using Quartus. Need help debugging. Any help will be ap...
10 years ago --- Quote Start --- The FPGA will only solve the logic part of your requirements - the logic only. If you specifically need the characteristics of a BJT then put a BJT down on your board! You will not get any resources inside the FPGA to do this part of your puzzle. Cheers, Alex --- Quote End --- Hi, I wrote the attached source codes for pmos and nmos. I need help with the pmos for it to have the characteristics previously described. Any ideas?
