10 years agoBJT Code needs Debugging
Hi, I'm trying to compile the attached source codes. The NPN & PNP BJTs are in VHDL and the diode code is in verilog. I am using Quartus. Need help debugging. Any help will be ap...
10 years agoThat looks to be the same VHDL as you posted in your first post. No. The 'electricalsystem' VHDL package is not synthesisable.
I'm unaware of tools that do what you want. Why on earth are you trying to put a BJT into an FPGA? This code will be to assist with a simulation. Cheers, Alex
