11 years agoBit widths for addition
Hi, I am trying to write a pipelined adder for a filter design. all the gaussianPixels are 8 bits wide. gaussianPartialSum0 <= ("00" & gaussianPixels(0)) + ('0' & gaussianPixels(3) & '0') ...
11 years ago --- Quote Start --- Yes - that should work. the numeric_std has a resize function that will get the correct size for you (though not append bits at the LSB) and if using the signed type, will sign extend the value. --- Quote End --- Ok. thank you. I will try that. These values are all unsigned so hopefully it wont do any bit extension or anything.
