18 years agoAnd the safe state machine option for Quartus II synthesis is documented in Altera docs: http://www.altera.com/literature/hb/qts/qts_qii51008.pdf. Other EDA tools gives the same behavior for this type of option I believe.
Safe State Machines The Safe State Machine option and corresponding syn_encoding attribute value safe specify that the software should insert extra logic to detect an illegal state and force the state machine’s transition to the reset state. ... It is important to note that the safe state machine value does not use any user-defined default logic from your HDL code that corresponds to unreachable states. Verilog HDL and VHDL allow you to explicitly specify a behavior for all states in the state machine, including unreachable states. However, synthesis tools detect if state machine logic is unreachable and minimize or remove the logic. Any flag signals or logic used in the design to indicate such an illegal state are also removed. If the state machine is implemented as safe, the recovery logic forces its transition from an illegal state to the reset state. ... Safe state machine implementation can result in a noticeable area increase for the design...
