SatishK
4 years agoBeckhoff (745C) Ethercat flex license set up support.
We have purchased ETHERCAT 1810/12 flex licenses from Vendor Beckhoff (745C), . We are struggling to setup the license file on server to use with Intel Quartus Prime lite edition. We need binaries to...
AR_A_Intel
4 years agoHello
Welcome to Intel forum. Could you help to reconfirm the license setup again. You can refer to link below for more detailed instructions for Setting up a license.
You can also refer this following YouTube for license setup. https://www.youtube.com/watch?v=Ob9ei5lMgGE
Let me know if this information is helpful.
SatishK
4 years agoHello Team,
The license file is set up as per the instructions.
The debug file showing the license check in and Check out, however user is still getting the “Time Limited” sof file output.
Attached herewith the logs and error snap. Can you please check and help. Please let me know if you can be available for troubleshooting meeting, I will schedule as per your availability.
Best Regards
Satish Khakare
