10 years agoBarrel shifter coding using mux
I need help building a barrel shifter that uses multiplexers and has three columns as stated in the attachment. Please help!
10 years ago --- Quote Start --- What help do you need? what problems are you having doing it yourself? --- Quote End --- Yes I am new to VHDL and don't quite understand all the commands I have one barrel shifter constructed but I don't know how to combine the other two barrel shifters with the signal command and I don't know exactly how I would write the code to get all barrels to shift. I know I probably need to select a signal that acts like a switch.
