15 years agoI always considered a bit silly that Quartus refuses to make a POF for Opencore evaluation.
--- Quote Start --- Well, it is quite obvious, because then you could just add some watchdog to your board that will reload the fpga after one hour and you would get the function of the ip-core for free. --- Quote End --- True, but if you insist, you can do a similar hourly reload through JTAG.
