15 years agoWhy is there a "flash programmer" menu item in the NIOS ide then?
Also, I was under the impression that "time-limited" means that when programmed via JTAG the device works for unlimited time, but when programmed by config flash chip it is time limited to 1 hour - am I incorrect? My use case is for a portable device, so I'm looking to be able to turn it on and use it without a super long jtag cable...
