SKarp6
6 years agoAXI Translator from Platform Designer (QSYS) doesn't follow AXI4-Lite protocol spec.
Hello All, This might be a known problem. It looks like AXI Translator module has a bug. When you pick AXI4-Lite on master side AXI Translator expects that RID and BID signals will be set by a modul...
RichardT_altera
5 years agoSorry that the case had been idling for quite sometimes. Do you able to solve the issue?
Is there any help still needed from your side?
