Avalon Verification IP Suite questions
- 5 years ago
Hi Eliyahu,
--- Is it possible to get a verification license and if not, how to avoid errors without changing files?---
Yes it is possible to get the license file and you can contact Mentor for that. Commenting out "altera_avalon_mm_monitor_coverage module" would result in following as you said
Error: (vsim-1) Unable to checkout verification license - testbench generation feature (randomize, randcase, randsequence, covergroup) is only supported with QuestaSim.
Therefore, I guess the only way to proceed with this to use Questasim
Hi Eliyahu,
