8 years agoAvalon to AXI bridge for Nios II in Qsys
Hello, I am trying to build a simple Qsys SoC consisting of a Nios II/e with on-chip memory. I also require to translate the Nios II signals from Avalon to AXI. Is there any IP in Qsys whic...
8 years agoI'm not sure why you don't want to just add the memory controller into Qsys, but I believe there is an Avalon to AXI bridge component in Qsys. You would connect the Nios to the Avalon side and export the AXI side to connect to the memory controller outside of Qsys.
