14 years agoAvalon-ST mux
Hello. Is there any way to set more then 2 inputs in AvST multiplexer component? When i set for example 3, the error appears:
Error: multiplexer_0: Channel isn't wide enough. :confused:Hello. Is there any way to set more then 2 inputs in AvST multiplexer component? When i set for example 3, the error appears:
Error: multiplexer_0: Channel isn't wide enough. :confused:Yes it is. Set a wider channel signal.
Oh, that was obvious :oops:. Thank you.
