11 years agoavalon memory mapped slave
hi. just a quick backgrund for the task at hand. i have a nios II system that writes/reads to onchip-memory and a custom-vhdl block using IOWR/IORD. I can write/read data to/from the vhdl block from ...
11 years agohi again.
got a avalon master and slave running in "my custom vhdl" the on-chip memory has base address 0x8000-0xFFFF, but how do i figure out where niosII is storing variables in the memory ? cant find a .map file (probably called something else). Anyway if i write to 0x8000 from vhdl code and read from 0x8000 in nios i dont get the correct data, so im thinking something else i writing to that addresse as well. thanks stefan
