PElm
8 years agoAutomatic use of internal block RAMs
I'm translating code from Xilinx devices to Intel to see if we could switch to Altera FPGAs. Xilinx tools automatically translate VHDL memory operations to block-ram without need to use macros or co...
Daixiwen
8 years agoAccording to the "Specifying Initial Memory Contents at Power-Up
" chapter in the document https://www.intel.com/content/www/us/en/programmable/documentation/sbc1513987577203.html#mwh1409959590153 , the recommended way to initialize the memory is to give a default value to the signal. Check if there is any sublte difference between your code and the example given by altera that could confuse the synthesizer.
