11 years agoAtomic opertations
I'm learning to program an FPGA using the OpenCL, in particular use DE1-Soc. I'm trying to use atomic operations as atom_add, atom_inc ecc. However, the compiler says: "ERROR: no matching function for call to 'atom_add.'" I also tried using atomic_add, but with same result. I also set# pragma OpenCL EXTENSION cl_khr_local_int32_base_atomics: enable. What else should I do?2 Replies
The error seems like something from the C compiler. Do you have the atomic add in the host or kernel code?
Atomic add is in the kernel code, I solved. Thanks for the replay.
