18 years agoHello,
you can answer the question yourself, if you ask: Could there be a reason to have a reset working without a clock present? If you see a reason, then you should use the first circuit, if not, use the "general" synchronisation circuit, as you like. One possible reason can be, that reset should cause all outputs to switch to a safe state. Regards. Frank
