18 years ago --- Quote Start --- The top circuit is design to go into reset asynchronously but come out of reset synchronously. The bottom circuit goes into and out of reset synchronously. The top circuit is important to use in cases were a reset stops the clock. --- Quote End --- Can you explain more on the statement " The top circuit is important to use in cases were a reset stops the clock"? Don't get a clear picture here...
