10 years agoastonishing facts about aocl compiler : vector_add -> No DSP used, y[i]=x[i] comp er
There are some facts about the AOCL compiler i find astonishing. aocl version 16.0.2.222, Quartus the same, 10AX115N3F40E2SG on Nallatech board pci385a and bsp. 1) the result of the compilati...
10 years ago --- Quote Start --- The Nallatech 385A BSP version r001.004.0002 for OpenCL SDK / Quartus Prime pro version 16.0.2 is now released. There are 2 versions of the Nallatech 385A BSP: 1. HPC BSP (2 x 40Gbps board-to-board IO channels) and 2. MAC BSP (2 x 10GbE MAC cores IO channels) Thanks G --- Quote End --- Thanks for the info. I think i will try it. Even if I'm a bit scared because the last time passing from the beta to the official release Nallatech had the idea of changing the name of the board making unusable binaries that required hundreds of hours of cpu time to build them up. grazie
