10 years agoastonishing facts about aocl compiler : vector_add -> No DSP used, y[i]=x[i] comp er
There are some facts about the AOCL compiler i find astonishing. aocl version 16.0.2.222, Quartus the same, 10AX115N3F40E2SG on Nallatech board pci385a and bsp. 1) the result of the compilati...
10 years ago1) Only a tiny percentage of the chip is being used here. And the percentages shown are integer-ized, so you may need to use a dozen DSPs to change the 0% to 1%. But if you want to scale up the size and performance try vectorizing or num compute units.
2) The aoc compiler uses Quartus under the hood, Quartus needs a lot of memory, 64GB is a good size. The error message you're getting (below) is definitely pointing to a system with too little memory. Error (114016): Out of memory in module quartus_syn (1688 megabytes used)
