FranciscoPolo
5 years agoAssociated Flash memory problem
I am using the Intel IP Parallel Loader in an Arria V FPGA wiht the Quartus Prime Sotware, I have no problem loading the IP program in the FPGA, the problem is with the flash memory used, in the appl...
FranciscoPolo
5 years agoThe answer given by you does not correspond to what I ask, I want to put the SST39VF3201 memory to be able to record it through a PFL and use it as a bootloader of another device, this memory is not and will not be used as a configuration memory of the FPGA
