8 years agoAssmerbler: Can't use configuration device EPCQL256 with selected programming mode
Hi all, I am trying to recompile the PCIE Avalon-MM DMA reference design for Arria 10 (http://www.alterawiki.com/wiki/reference_design:_gen3x8_avmm_dma_-_arria_10). Since I modified a register ...
8 years agoHi,
I notice the picture degrade so much until nothing can be seen. 1. Since you are using original kit out of box, compile log is not needed. 2. I put it in doc attachment so picture wont degrade, it is all about setting must be correct. 3. qsf file is the one storing your setting, you may change from qsf file itself or open Quartus setting windows to change. For qsf file, you can also delete whole line instead of edit wording, Quartus is intelligent enough to replace correct setting. Best Regards, Tzi Khang, Lim (This message was posted on behalf of Intel Corporation)
