8 years agoAssmerbler: Can't use configuration device EPCQL256 with selected programming mode
Hi all, I am trying to recompile the PCIE Avalon-MM DMA reference design for Arria 10 (http://www.alterawiki.com/wiki/reference_design:_gen3x8_avmm_dma_-_arria_10). Since I modified a register ...
8 years agoIn order to proceed in helping you, I need gather your info.
First, you may confirm your programming mode as shown in picture 2, picture 3, and picture 4. If this fix the problem, just skip next step(s). Also, make sure you selected correct device in picture 4 device window. Second, which one are you converting your sof file into jic or pof or etc, please provide me the info. Third, if you still faced problem, share me your log while compile like shown in picture 1. You may attach the windows while compile to get the log. Share me your board info like board model/kit, memory type, JTAG/AS/etc header, for second and third solving to proceed. Programming mode is determined by the connector and flash memory you are using. Would suggest that: https://www.altera.com/products/boards_and_kits/all-development-kits.html (https://www.altera.com/products/boards_and_kits/all-development-kits.html) Download, install and compiled the h/w and s/w files for the kit model. Then, program them using the instruction in the pdf documentation. For custom board, paste full/all compile log here. Regarding error 210027, an alternative manual method to select device is open your .qsf file using notepad, fix the line e.g. set_global_assignment -name FAMILY "Arria 10 (GX/SX/GT)". Not recommended as pin assignment/etc settings might not be updated, it is recommended to go for picture 2, 3, 4 to select device and save it. Best Regards, Tzi Khang, Lim (This message was posted on behalf of Intel Corporation)
