10 years agoAssembler internal error Aria 10
Hi, I experience a crash during assembler stage for my design. Attached is the report generated by Quartus. As far i can understand there is an issue with some constraints regarding the IO...
10 years ago --- Quote Start --- Thats a tool crash - you'll have to raise a mysupport ticket to find out the cause. Have you tried using Q16 instead of 15? --- Quote End --- I think i will ask the support , it is just weird because with the similar design and another (more complex) PLL it doesn't crash. I wonder if there is some assembler parameter that has to be set...
