10 years agoASMI IP Simulation
Hi I am trying to simulate the ASMI IP with Modelsim-Altera. I am a complete n00b and the instructions to simulate IP Cores are not very clear to me.
I can compile the design and make it work on the FPGA. But when I try it on Modelsim the IP does nothing. I have included the .qip and .sip files. My flow to the simulation works as it follows:- I click on Analysis and Synthesis.
- I go to Tools>Run Simulation Tools>RTL Simulation
- When Modelsim pops up I type on the console :
vsim work.topfilename - I create stimulus (manually, as there are not many signals).
1 Reply
Hi there,
I have exactly the same issue. Just wondering if you was able to figure this out. Also, you mentioned that you was able to make it work in hardware, I had no luck in that either. Do you have a simple test project to share? I really to like to get it fixed. Thanks, Yev
