KAkyo
7 years agoASE Simulation Syntax Error(?)
Hello, I am trying to run ASE simulation for AAL application (which is an on-going project, cannot switch to OPAE right now). When I "make" the simulation side, once it worked and started to wait fo...
MuhammadAr_U_Intel
Contributor
7 years agoHi,
This Error seems like Modelsim can't recognize the syntax did you tried to look at the codes pointed in Error message ?
How is the simulation scripts generated, is the correct command used for compilation like "-sv" switch for system verilog code.
You may refer to my reply in another thread related to AAL.
