9 years agoArriv 10 vs cyclone V for OpenCL
Hellow. I am beginner of the OpenCL. So I select the proper device for OpenCL. My boss want to use the arria 10 board. Because nowdays many people are use this device. But when I research ...
9 years ago@kangchusuk, if you are sure that the limited hardware resources available on Cyclone V is enough for you, then the Cyclone V board from Terasic should work just fine. Check the pages zxustc mentioned and decide how much logic you need. You can also consider buying a Stratix V board if you think Cyclone V is not enough, but Arria 10 is too much.
