Arria10 SXでCritical Warning (17951)、(18655)を消す方法はありますでしょうか。
- 7 years ago
Well, these warnings are generated because there are unused transceiver RX channels in the device and is a normal warning message.
Unused transceiver TX channels in your Arria® 10 device may degrade over time when using the Quartus® Prime software version 16.0 and earlier.
The Quartus Prime software generates a warning message if your design contains unused transceiver channels. The warning message states that performance of unused channels may degrade over time if not properly preserved with the following Quartus Settings File (QSF) assignments.
Global Assignment
set_global_assignment -name PRESERVE_UNUSED_XCVR_CHANNEL ON
Pin Specific Assignment
set_instance_assignment -name PRESERVE_UNUSED_XCVR_CHANNEL ON -to pin_name
In the Quartus Prime software version 16.0 and earlier, the QSF assignment only preserved the unused receiver channel and did not properly preserve the unused transmitter channel.
You can also try the following to remove the warning:
Eliminate the warning by performing one of the following options:
1. Enable unused rx clock workaround. In your QSF file, insert the following assignment:
set_global_assignment -name ENABLE_UNUSED_RX_CLOCK_WORKAROUND ON
2. Disable the warning (do this only if you are certain that you will not use other transceiver channels in your design). In your QSF file, insert the following assignment:
set_global_assignment -name MESSAGE_DISABLE <message_id>
These warnings are normal
- G07 years ago
Hi, Nathan.
Sorry for casuing your misunderstanding, I did not have an error when adding "ENABLE_UNUSED_RX_CLK", it just have no effect on my case. The critical warnings still appear.
And I tried to add the set_global_assignment -name MESSAGE_DISABLE <message_id> again and this time the error did not appear.
Thanks a lot for your help!
