10 years agoArria II GX TTK configuration problem running at 6Gbps
Hi all, I am trying to get the TTK to work @ 6 Gbps with ARria-II GX and having difficulties. I was wondering of anyone has suggestions or a TTK project with 6 Gbps Arria II GX to share. Alte...
10 years ago --- Quote Start --- We bought a SATA core (Intelliprop) and the transceivers are buried in the core. Sorry, again not much help. I'll take a look at the TTK stuff tomorrow and see if I can remember what we did. I recall it being pretty easy to use once I figured out the interface. Just picked a speed and then had it sweep all parameters. --- Quote End --- I've captured the screenshots of each PHY configuration to see how-to consolidate the 6 Gbps config. I guess I don't understand enough to configure the "custom PHY" to do neither double-rate i.e. "wide FPGA Fabric config" nor 8b/10B encoding enabling. Attached... The CPRI PHY is inside IP and separate RX & TX configs. Thank you for quick reply BTW.
