ZLIN5
8 years agoArria 10 Power Monitor GUI not responding on Ubuntu 16.04
Hello! I'm trying to use the Power Monitor of the Board Test System to do measurement to my Arria 10 GX FPGA. The problem is when I launch the script, it just got stuck and all the buttons on the GUI...
YuanLi_S_Intel
8 years agoHi ZLIN5,
After you reported the query, I have tested the Power Monitor.exe which is there in the below Installation path
\\Working_directory \arria10GX_10ax115sf45_fpga_v15.1.2\examples\board_test_system
And it is able to run the program. The OS is Windows. For the Linux environment, I have limited access to Ubuntu. But when I check from our internal data base could not able to see any bug reported for the Power Monitor.sh. The only thing you have to make sure here is the OS should be 64 bit.
So, requesting to check the OS and any other process is blocking the program. And as a recommendation, kindly run on root prompt.
Hope it helps.
YL
