Arria 10: No devices attached for package
Hello.
I have a troubles with install Arria 10 board on my system.
I use this instruction:
https://www.intel.com/content/www/us/en/programmable/documentation/tgy1490191698959.html
Program fpga was successfully by command:
quartus_pgm -c 1 -m JTAG -o "p;top.sof"
But there is no board in device manager.
All switches placed by instruction below.
My board have a serial/part number:
6XX-44366R-0G, 10APCIe0001610.
I also made attemption to install Jungo WinDriver, but all in vain.
May be instruction not correct for my board?
My operating system is Win10. Mother board: p10s-c/4L.
Please help me.
- BoonBengT_Altera
Moderator
Hi @Jentos,
Thank you for posting in Intel community forum, hope this message find you well and apologies for the delayed in response.
May I know what OS are you using for your host system? Can you also please check if there any error message upon checking for the jtagconfig command? Are you able to see the cable driver are successfully installed (i.e. Device manager)Warm regards.
BB- Jentos
- BoonBengT_Altera
Moderator
Hi @Jentos,
With the JTAG cables showing up in the device manager, I would assume that the cables drivers are successfully installed. Did you managed to installed the runtime driver successfully after running aocl install? Can you please run a aocl diagnose and see what are the output generated?
The board you are having is a development kit board and it should be compatible with this instructions.Warm Regards
BB
