corestar
Contributor
5 years agoArria 10 Native Floating Point Adder Issue
I'm using Quartus 19.1 Standard and there is an odd issue with the native Arria 10 floating point adder. As shown in the attached, the Ax input has a latency of 3 clocks but the Ay of only two. So th...
- 5 years ago
You can actually click on that register from the Native DSP Block floating Point GUI to change the clock source and also disable that register if this is not required.
Regards -SK
SengKok_L_Intel
5 years agoThank you for the feedback.
If further support is needed in this thread, please post a response within 15 days. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
