11 years agoArria 10 fPLL false warning in Quartus II
Just to share that in case you are using Arria 10 fPLL, you might observe some false warnings during instantiation. You can refer to the following KDB solution for further details: https://www.altera.com/support/support-resources/knowledge-base/solutions/rd06252015_504.html3 Replies
Thanks for sharing.
--- Quote Start --- Hi, Just to share that in case you are using Arria 10 fPLL, you might observe some false warnings during instantiation. You can refer to the following KDB solution for further details: https://www.altera.com/support/support-resources/knowledge-base/solutions/rd06252015_504.html --- Quote End --- Thank you for the info. - Altera_Forum
You are welcome.
