MathiasB
5 years agoArria 10: Connect TSE IP to RGMII PHY
Hello all,
I am working on a board embedding a Arria 10 SX SoC, connected to an Ethernet PHY.
I would like to use the Triple Speed Ethernet (TSE) IP with this PHY. However, its interface is RGM...
- 5 years ago
HI,
Unfortunately this is Arria 10 device architecture limitation when interacting with RGMII PHY interface.
The limitation is on the data transfer path between FPGA IO circuitry block to FPGA core logic (where soft IP solution is located like TSE)
Therefore, Unfortunately there is no solution for it.
Thanks for your understanding
dlim
MathiasB
5 years agoThank you for your answer.
Does that mean that I have to use the HPS to interface the Arria 10 to a RGMII Ethernet PHY?
This at least should be possible, based on https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/arria-10/a10_5v4.pdf §18.1.5
