You want that I make like that :
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity cdm is
--generic (
-- width : natural :=4);
port (
clk : in std_logic ;
rst : in std_logic ;
data: in std_logic ;
odata: out std_logic ;
CD : in std_logic_vector(15 downto 0) ;
isis :out integer range 0 to 3 ;
S :out std_logic_vector(3 downto 0 ));
end entity ;
architecture beh of cdm is
--type tab is array(3 downto 0)of std_logic_vector(15 downto 0);
signal i :integer range 0 to 3 ;
signal idata :std_logic ;
--signal itab :tab ;
begin
code :process(clk,rst)
begin
if(rst='1')then
i<="0000" ;
else
if(clk'event and clk='1')then
i<=i+1 ;
case i is
when 0 =>s(0)<=not(CD(15 downto 12) xor (data));
when 1 =>s(1)<=not(CD(11 downto 8) xor (data));
when 2 =>s(2)<=not(CD(7 downto 4) xor (data));
when 3 =>s(3)<=not(CD(3 downto 0) xor (data));
if i=3 then
idata<=data ;
end if ;
end case ;
end if ;
end if ;
end process ;
isis<=i;
odata<=idata ;
end architecture ;
?? ! Thank you in advance
