FCive's avatar
FCive
8 years ago
aocl program and aocl diagnose commands fail
Dear community,
I started to work with Intel OpenCL SDK and DE5-Net. I Installed the BSP support for DE5-Net provided by Terasic into the OpenCL directory of IntelFPGA software and I followed the instructions in the DE5-Net OpenCL guide. I have executed successfully the command "aocl install" and "aocl flash acl0 hello_world.aocx". I did a power cycle of the PC and it seems that the "acl" device is inside /proc/devices. You can find the output of "dmesg" command about the PCI driver and the output of "cat /proc/devices | grep acl" below:
dmesg
[ 3.975583] FPGA manager framework
[ 3.981245] fpga_manager fpga0: Altera CvP FPGA Manager @0000:4f:00.0 registered
[ 3.981407] aclpci_drv: loading out-of-tree module taints kernel.
[ 3.981490] aclpci_drv: module verification failed: signature and/or required key missing - tainting kernel
[ 3.981687] aclpci_init (692):
[ 3.981688] ----------------------------
[ 3.981688] aclpci_init (693):
[ 3.981689] Driver version: 18.1.
[ 3.981694] aclpci_init (714):
[ 3.981694] pci_register_driver
[ 3.981719] aclpci_init (720):
[ 3.981719] success
239 acl
But when I run the command "aocl program acl0 hello_world.aocx" I got this output:
aocl program: Running program from /home/fciverch/intelFPGA/18.1/hld/board/terasic/de5net/linux64/libexec
Unable to open the device acl0.
aocl program: Program failed.
For "aocl diagnose" the output is the following:
Verified that the kernel mode driver is installed on the host machine.
Using board package from vendor: Terasic Corporation
Querying information for all supported devices that are installed on the host machine ...
Found no active device installed on the host machine.
Please make sure to:
1. Set the environment variable AOCL_BOARD_PACKAGE_ROOT to the correct board package.
2. Install the driver from the selected board package.
3. Properly install the device in the host machine.
4. Configure the device with a supported OpenCL design.
5. Reboot the machine if the PCI Express link failed.
DIAGNOSTIC_FAILED
There is no /dev/acl0 peripheral created and I tried to create it manually using the command "mknod /dev/acl0 c 239 0", but the problem persists.
Could you please give me some suggestions to fix the issue? Why the peripheral is inside the /proc/devices list but the /dev/acl0 is not created?
I use Quartus prime standard 18.1 and OpenCL SDK 18.1. The BSP for DE5-Net is the latest 18.0 with some changes to be compatible with 18.1.
The operative system is Ubuntu 16.04 equipped with Intel Xeon processor and the kernel is 4.15.0-38-generic.
Thank you for your support.
Federico Civerchia
  • Finally I fix the problem. The kernel modules "altera_cvp" and "fpga_mgr" managed the PCIe instead of "aclpci_drv". Removing that modules fixed the issue.
    Federico
1 Reply
  • FCive's avatar
    FCive
    Federico
