8 years agoAOCL install failing to find kernel source files
Hello I am trying to install the aocl drivers on my machine but I am getting the following error: # aocl install .
aocl install: Running install from /opt/intel/intelFPGA_pro/17.0/hld/board...
8 years agoBy default CentOS will install kernel headers for the latest available kernel, which might be newer than your active kernel. Apart from installing kernel headers, you should also update your existing kernel and reboot your machine and after that make sure your kernel and kernel header versions match.
