mvemp's avatar
mvemp
8 years ago
aocl clang exists but not working
I am trying to install the new version v18.1 AOCL. I was able to install quartus pro setup and aocl pro setup file.
When I execute aoc kernel.cl, I get error
" Error: aoc: Executable /opt/FPGA/hld/linux64/bin/../../llvm/bin/aocl-clang exists but is not working!
The cause of failure cannot be determined. Run executable manually and watch for error messages."
and when I execute /aocl-clang I get this error
./aocl-clang: error while loading shared libraries: libdsdk.so: cannot open shared object file: No such file or directory
Any idea about this?
My path : echo $PATH
/opt/FPGA/hld/bin:/opt/FPGA/quartus/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
My Library path :
echo $LD_LIBRARY_PATH
/opt/FPGA/hld/linux64/lib/:/opt/FPGA/hld/board/a10_ref/linux64/lib:/opt/FPGA/hld/host/linux64/lib:
  • HRZ's avatar
    HRZ
    You have an extra colon at the end of your LD_LIBRARY_PATH; hence, the last path becomes "/opt/FPGA/hld/host/linux64/lib:" instead of "/opt/FPGA/hld/host/linux64/lib" which is invalid. I was scratching my head for 5 minutes as to why your configuration is not working even though it should, until I saw the colon. 😅
  • mvemp's avatar
    mvemp
    I tried changing that.
    /opt/FPGA/hld/linux64/lib:/opt/FPGA/hld/board/a10_ref/linux64/lib:/opt/FPGA/hld/host/linux64/lib
    but still same error. I have seen lib files in all these three paths
    /opt/FPGA/hld/linux64/lib$ ls
    __ocl_svml_e9.so clbltfne9_img_cbk.rtl emu_libs libaoc_clang_decrypt.so libelf.so.0
    __ocl_svml_h8.so clbltfnh8.rtl libOclCpuBackEnd.so libaxerces-c.so libintelocl.so-gdb.py
    __ocl_svml_l9.so clbltfnh8_img_cbk.rtl libOclCpuDebugging.so libaxerces-c.so.26 libintelocl_emu.so
    __ocl_svml_z0.so clbltfnl9.rtl libOpenCL.so libcl_logger_emu.so libtask_executor_emu.so
    aclomp.so clbltfnl9_img_cbk.rtl libOpenCL.so.1 libclang_compiler.so sources
    aclomptbb.so clbltfnz0.rtl libOpenCL.so.2.0 libcommon_clang.so
    cl.cfg clbltfnz0_img_cbk.rtl libalteracl.so libcpu_device_emu.so
    clbltfne9.rtl dspba libalterahalmmd.so libelf.so
    /opt/FPGA/hld/board/a10_ref/linux64/lib$ ls
    libaltera_a10_ref_mmd.so
    /opt/FPGA/hld/host/linux64/lib$ ls
    libOpenCL.so libaltera_mpfr.so libaoc_cosim_mmd.so libelf.so.0 libzmq.so.1
    libOpenCL.so.1 libaltera_mpir.so libaoc_cosim_msim.so libz.so libzmq.so.1.0.1
    libOpenCL.so.2.0 libalteracl.so libaoc_cosim_msim32.so libz.so.1 sources
    libacl_emulator_kernel_rt.so libalterahalmmd.so libelf.so libzmq.so
    I really dont see libdsdk.so
    Do you have this libdsdk.so file in any of your paths? May be my installation is wrong.
  • HRZ's avatar
    HRZ
    On my environment that file is located at "*installation_dir*/hld/linux64/lib/". However, I do NOT have that folder added to my LD_LIBRARY_PATH and everything seems to work correctly as it is.
  • @mvemp​
    Are you still facing this issue or you are able to proceed ?
    May I know what version of Linux distribution you are using ?
    Arslan
