9 years agoaoc: unable to generate hardware for hello_world example
Hello, I am trying to generate the aocx file for the hello_world design example from the altera website. I'm using aoc and quartus 17.0 in Linux and when i try to run the command "aoc -v device/...
9 years ago --- Quote Start --- Hi shruthiarav, can you tell us how you resolved this problem. I am having exactly the same issue. --- Quote End --- Well, my issue was because of some issues with how the ACDS was installed. I ended up having to reinstall the whole package. You could check if yours is an installation issue as well, by trying to invoke quartus_syn by itself(since the segment violation is in the quartus_syn module). quartus_syn is located in the $QUARTUS_ROOTDIR/bin - just try ./quartus_syn. If the same segment violation error occurs then, then it is an error related to the installation or it could be some OS compatibility issues.
