9 years agoaoc: unable to generate hardware for hello_world example
Hello, I am trying to generate the aocx file for the hello_world design example from the altera website. I'm using aoc and quartus 17.0 in Linux and when i try to run the command "aoc -v device/...
9 years agoOkay, that should be more than enough. Still, the "Out of memory" message in the log is generally accurate. Are you running multiple compilations in parallel? Maybe someone else was also using the machine for some memory-heavy operation?
Also test with Quartus/AOC v16.1.2 for the sake of it; a lot of things related to OpenCL seems to have changed in v17.0, and not all of them for the better...
