11 years agoaoc generated .attrib file meaning
Hi All, I am now using AOC to generate .aocx for MatrixMul example. Two hours later, it generate .aocx file successfully. It also generate some report files. One of the files is matrixmu...
11 years ago --- Quote Start --- Speaking of .attrib file: does someone know the meaning of the fields throughput and copyfactor? For what is throughput used here? Work item per seconds? --- Quote End --- Just forget about it. It is not that accurate since it is really hard to predict the OpenCL kernel performance.
