8 years agoaoc compile error: using host channel feature
Hi, I am writing a simple OpenCL code for testing host channel feature introduced 17.1. The code is as follows: # pragma OPENCL EXTENSION cl_intel_fpga_host_pipe : enable
kernel void clk...
8 years ago --- Quote Start --- Hi, May I know are you using the dedicated BSP(a10gx_hostch) for this feature compilation? Board list: a10gx Board Package: C:\intelFPGA_pro\17.1\hld\board\a10_ref a10gx_hostch Board Package: C:\intelFPGA_pro\17.1\hld\board\a10_ref Channels: host_to_dev, dev_to_host Regards, CloseCL (This message was posted on behalf of Intel Corporation) --- Quote End --- Thank you for your advice. There are no errors when using the BSP 'a10gx_hostch', but the warning described below are remained. clkernel.cl:1:26: warning: unknown OpenCL extension 'cl_intel_fpga_host_pipe' - ignoring Anyway, the compilation of the design is finished successfully.
