8 years agoaoc compilation fails: Error: save_system kernel_system.qsys (CENTOS 7)
Hi, A colleague and I are having issues compiling the fft1d example provided by Intel/Altera. OCLSDK passes first stage compilation fine, but fails with the message 'Error: save_system kernel_s...
8 years ago --- Quote Start --- So, you have successfully compiled other code on the same machine? If "quartus_sh_compile.log" is not generated, then it means compilation is failing very early in the process. Do you have enough free space on your disk? Also, have you tried removing the existing compilation folder for fft1d and retrying the compilation? --- Quote End --- Disk space isn't an issue (200 GB spare). Have tried removing the compilation folder and recompiling, but the results is the same QSYS-script FAILED error message. Tried compiling another example (vector_add) and it failed in the same way. I guess the quartus_sh_compile.log must be generated from the files when we were compiling on windows, and when we copied the examples across, we must have copied the logs too. Any other ideas?
