8 years agoaoc compilation fails: Error: save_system kernel_system.qsys (CENTOS 7)
Hi, A colleague and I are having issues compiling the fft1d example provided by Intel/Altera. OCLSDK passes first stage compilation fine, but fails with the message 'Error: save_system kernel_s...
8 years agoSo, you have successfully compiled other code on the same machine? If "quartus_sh_compile.log" is not generated, then it means compilation is failing very early in the process. Do you have enough free space on your disk? Also, have you tried removing the existing compilation folder for fft1d and retrying the compilation?
