8 years agoaoc 17.1 compilation failed
Hi guys, I've installed DE5ANET_E1_OpenCL_BSP_17.1 from Terasic and tried to compile vector_add example, but encountered an error (Attached). aoc -version Intel(R) FPGA SDK for OpenCL(TM),...
8 years agoThe process is failing due to some issue with importing the base design. This is either caused by a broken/incorrect BSP installation, or some issue with the BSP itself. Try reinstalling the BSP and rechecking your environmental variables. If the issue was not resolved, I recommend contacting Terasic.
