11 years agoaoc -c -g kernel.cl --report error
when i run the command "aoc -c -g kernel.cl --report ", i met an error like this :
" system_integrator: hdl.cpp:459: hdl::Signal1::Dimension::Dimension(int, int): Assertion `size > 0' failed.". who can tell me the reason for showing this error and how to slove it? thank you!1 Reply
Do not name your .cl OpenCL kernel source file "kernel". Naming the source file kernel.cl causes theAOC to generate intermediate design files that have the same names as certain internal files, whichleads to an compilation error.
Quoted from <<altera sdk for openclprogramming guide (https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/hb/opencl-sdk/aocl_programming_guide.pdf)>> (Page 1-14)
