ZSher
8 years agoAny way to measure external memory performance?
Hello all, I am working on an accelerator design that uses external memory. I would like to profile the memory to see if the design is making use of the available bandwidth, but I can't seem to find...
ZSher
8 years agoI have seen that since I posted this, I tried that and was unable to see how you could measure the bandwidth with it. I linked it to the Efficiency monitor but I did not see any activity reported even when the bus would definitely be in use. What needs to be enabled to use the toolkit for this?
