11 years ago
Another Tread on No Output from printf in NIOS
Hi ive read alot of post on this problem (no output in nios console) from alt_printf and printf. But found no solution so far.
The code is running (leds to indicate), i can breakpoint in the code, reg,vars etc gets updated.
ive tried the following.
*) tried to delete .metadata for eclips project and import again
*) tried to create a new project (on chip temp demo from altera)
*) checked std(i,o,err) is set to jtag_uart_0
*) jtag i Qsys
*) no optimizer under bsp settings for NIOS
*) -g compiler option for debug under bsp for NIOS
*) download of .elf file works
*) no timing constrain error's when compiled
I have a project running and working fine with the console, but cant seem to create a new one that works..
the one i have working was done under Windows7 and now im running windows10 (dont think this is the problem but thought i would mention it.)
Software:
Quartus v 15
Java v 8 update 60
Eclips
Version: Kepler Service Release 2
Build id: 20140224-0627
its properly a minor settings problem somewhere, just cant find it.
Thanks in advance
