11 years agoAnother beginners question
Being new to FPGA's ( started yesterday ) when I was given an Altera DE2-115 I find I keep coming up with lots of questions that I dont know the answer to I have been reading all I can in t...
11 years agoYour code is not quite right ... your counter is not 28-bits wide. You've solved a synthesis error by reducing your counter width. Here's the fixed code;
Library IEEE;
Use IEEE.numeric_std.all;
use IEEE.STD_Logic_1164.all;
entity Led_Blink is
port
clk : in STD_Logic;
q : out unsigned (3 downto 0);
Dec_Out :out unsigned (6 downto 0)
end Led_Blink;
architecture Counter of Led_Blink is
signal count : unsigned(27 downto 0);
signal q_out : std_logic(3 downto 0);
begin
-- 28-bit counter
process (clk)
begin
if rising_edge (clk) then
count <= count + 1;
end if ;
end process;
-- Extract the 4-MSBs and cast unsigned to std_logic_vector
q_out <= std_logic_vector(count(27 downto 24));
-- 4-bit output (pre-VHDL-2008 would not let you read 'output' ports)
q <= q_out;
-- Decode the 4-bit count
Process (q_out)
begin
case q_out is
when "0000" =>
Dec_Out <= "1000000";
when "0001" =>
Dec_Out <= "1111001";
when "0010" =>
Dec_Out <= "0100100";
when "0011" =>
Dec_Out <= "0110000";
when "0100" =>
Dec_Out <= "0011001";
when "0101" =>
Dec_Out <= "0010010";
when "0110" =>
Dec_Out <= "0000011";
when "0111" =>
Dec_Out <= "1111000";
when "1000" =>
Dec_Out <= "0000000";
when "1001" =>
Dec_Out <= "0011000";
when others =>
Dec_Out <= "1111111";
end case;
end process ;
end Counter;
Note how I created an internal signal q_out with the 4 MSBs of the counter that was then used as the input to the 7-segment decoder logic? If I did not do that, I would have had to define the q output as buffer. That does not descibe the logic "correctly" as far as I am concerned, so I typically introduce an internal signal. I'm pretty sure VHDL-2008 allows you to read "output" ports, but I don't mind the coding style of using internal signals, so I still use them. Cheers, Dave
