11 years agoAnother beginners question
Being new to FPGA's ( started yesterday ) when I was given an Altera DE2-115 I find I keep coming up with lots of questions that I dont know the answer to I have been reading all I can in t...
11 years ago --- Quote Start --- I would add that you do make a schematic design, but on paper. First think about the hardware you want, then write HDL to make it. --- Quote End --- That is a good point. If you cannot draw a block diagram, or the block diagram looks too complicated, then often your design is too complicated. I often apply this philosophy to my state machine designs; I get them working, then as I document them using Algorithmic State Machine (ASM) charts, I often realize that I can simplify them. (Often I can simply copy a working design and modify it too, or generalize it to cover a new use case). Don - there are plenty of resources on this page (they're not all beginner level, but you can at least see examples of code and documentation). https://www.ovro.caltech.edu/~dwh/correlator/cobra_docs.html Cheers, Dave
